Ana içeriğe geç
Midiman Oxygen 8 Keys Replacement
Neye ihtiyacın var
  1. Midiman Oxygen 8 Keys Replacement, Midiman Oxygen 8 Backplate Disassembly: adım 1, 2 resimden 1. Midiman Oxygen 8 Keys Replacement, Midiman Oxygen 8 Backplate Disassembly: adım 1, 2 resimden 2.
    • Remove the 8 mm M3 Phillips head self tapping machine screws.
    • Several of the screws are in narrow, deep sockets; make sure to use an appropriate screw driver to remove them so as not to damage the cover during removal.
    • Remove all 13 of the back plate screws.
    FixBot'a Sor
    Yorum Ekle
  2. Midiman Oxygen 8 Keys Replacement: adım 2, 2 resimden 1. Midiman Oxygen 8 Keys Replacement: adım 2, 2 resimden 2.
    • Remove the two highlighted 10 mm M3 galvanized machine screws using the J1 head fro the iFixit Tool Kit or a comparable tool.
    FixBot'a Sor
    Yorum Ekle
  3. Midiman Oxygen 8 Keys Replacement: adım 3, 3 resimden 1. Midiman Oxygen 8 Keys Replacement: adım 3, 3 resimden 2. Midiman Oxygen 8 Keys Replacement: adım 3, 3 resimden 3.
    • Removal of Ribbon Cables
    • Prior to removal, note, mark, or take photo’s of the position of all connectors. Specifically note the side that the red wire is on, as ribbon cables are polarized cables that must be re-installed correctly. Installing the cables backwards may cause damage to the device or significantly hinder the troubleshooting process.
    • To separate the back plate, remove all five cables that connect to the motherboard but do not originate from the back plate; the key assembly, LCD circuit, rotor tuning circuit, and the pitch and modulator circuits. None of these cables require tools to remove, simply apply firm upward pressure to remove them.
    FixBot'a Sor
    Yorum Ekle
  4. Midiman Oxygen 8 Keys Replacement: adım 4, 2 resimden 1. Midiman Oxygen 8 Keys Replacement: adım 4, 2 resimden 2.
    • Remove the key assembly from the key board.
    • What remains is the back plate and the top plate assemblies.
    FixBot'a Sor
    Yorum Ekle
  5. Midiman Oxygen 8 Keys Replacement, Keys: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • The keys are retained via a tension spring. The removal of these springs is simple using the hooked needle point tweezers from the IFixit Toolkit.
    FixBot'a Sor
    Yorum Ekle
  6. Midiman Oxygen 8 Keys Replacement: adım 6, 2 resimden 1. Midiman Oxygen 8 Keys Replacement: adım 6, 2 resimden 2.
    • To remove, simply insert one of the tweezer ends through the opening at the end of the spring.
    • Press the end between the spring windings after the windings start to reduce in size towards the inside of the spring.
    FixBot'a Sor
    Yorum Ekle
  7. Midiman Oxygen 8 Keys Replacement: adım 7, 1 resimden 1.
    • Next, clasp the spring windings with the tweezers and gently apply tension outward.
    • The spring should thin slightly and be easily raised up and out of the retaining keyway.
    • This will free the key from the keyboard assembly for repair or replacement.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Scott Miller
437 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-6, Sullivan Fall 2016 USF Tampa, Team 1-6, Sullivan Fall 2016 üyesi
USFT-SULLIVAN-F16S1G6
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 20
Son 30 gün: 50
Her zaman: 1,143
