Giriş
A common problem with this radio is the buttons getting stuck in place. This is usually due to a small foreign object obstructing the normal movement of the buttons. It may sometimes be necessary to get behind these buttons in order to clean out the problem!
Neye ihtiyacın var
First, apply pressure with your thumb on the top of the battery cover.
Next, pull down on the cover until it begins to slide.
Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
Once the back case is already off, use your fingers to lift up the circuit board from the side opposite the antenna.
Grasp the rubber cast around the buttons from one side, and slowly lift upwards. Make note of which way the buttons fit into the plastic casing!
At this point, the buttons can be cleaned in accordance with the radio buttons are stuck or sticking troubleshooting guide.
2 farklı kişi bu kılavuzu tamamladı.
