Ana içeriğe geç
Mill Cutter Paper Stripper Replacement
Neye ihtiyacın var
    1. Mill Cutter Paper Stripper Replacement, Mill cutter paper stripper set and stripper guide set: adım 1, 1 resimden 1.
      • Unplug the shredder from the wall electrical outlet.
      • Remove the shredder from its catch basket and place it face down on a flat surface.
      FixBot'a Sor
      Yorum Ekle
    2. Mill Cutter Paper Stripper Replacement: adım 2, 3 resimden 1. Mill Cutter Paper Stripper Replacement: adım 2, 3 resimden 2. Mill Cutter Paper Stripper Replacement: adım 2, 3 resimden 3.
      • Locate the seven case screws and remove them with a Phillips screwdriver. The screws are identified by the seven marked circles. The screws are 15 mm in length and the head diameter is 5 mm.
      • Remove the manufacturer’s label in order to get to one of the hidden screws, if applicable.
      FixBot'a Sor
      Yorum Ekle
    3. Mill Cutter Paper Stripper Replacement: adım 3, 2 resimden 1. Mill Cutter Paper Stripper Replacement: adım 3, 2 resimden 2.
      • Remove the screws connecting the stripper guide and the base of the shredder's housing unit with a Phillips screwdriver. The diameter head and screws are 10 mm in length.
      FixBot'a Sor
      Yorum Ekle
    4. Mill Cutter Paper Stripper Replacement: adım 4, 2 resimden 1. Mill Cutter Paper Stripper Replacement: adım 4, 2 resimden 2.
      • Once all of the screws have been removed, pull the casing apart.
      • Remove the stripper guide from the housing unit.
      • Use caution to prevent the trigger guard from falling apart.
      FixBot'a Sor
      Yorum Ekle
    5. Mill Cutter Paper Stripper Replacement: adım 5, 3 resimden 1. Mill Cutter Paper Stripper Replacement: adım 5, 3 resimden 2. Mill Cutter Paper Stripper Replacement: adım 5, 3 resimden 3.
      • Remove the e-clips from the gears on the left side with a flathead screwdriver.
      • Remove screws from the gear box cover on the right side with a Phillips screwdriver. The screws are identified by the two marked circles. The screws are 7 mm in length and the head diameter is 3 mm.
      FixBot'a Sor
      Yorum Ekle
    6. Mill Cutter Paper Stripper Replacement: adım 6, 3 resimden 1. Mill Cutter Paper Stripper Replacement: adım 6, 3 resimden 2. Mill Cutter Paper Stripper Replacement: adım 6, 3 resimden 3.
      • Remove the gears from both sides.
      • If the gears are hard to remove, use a flathead screwdriver to help remove them. The gears also may be greasy so place them on a paper towel or newspaper.
      • Remove the screws from the gearbox side plate with Phillips screwdriver to get to the gears. The screws are 7 mm in length and the head diameter is 3 mm.
      FixBot'a Sor
      Yorum Ekle
    7. Mill Cutter Paper Stripper Replacement: adım 7, 2 resimden 1. Mill Cutter Paper Stripper Replacement: adım 7, 2 resimden 2.
      • Replace the mill cutter paper stripper set and stripper guide set.
      • Use protective gloves as the blades are very sharp.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 37
Her zaman: 1,997
