Ana içeriğe geç
Milwaukee 2704-20 Outer Case Replacement
Neye ihtiyacın var
  1. Milwaukee 2704-20 Outer Case Replacement, Outer Case: adım 1, 2 resimden 1. Milwaukee 2704-20 Outer Case Replacement, Outer Case: adım 1, 2 resimden 2.
    • Remove the battery from the drill.
  2. Milwaukee 2704-20 Outer Case Replacement: adım 2, 3 resimden 1. Milwaukee 2704-20 Outer Case Replacement: adım 2, 3 resimden 2. Milwaukee 2704-20 Outer Case Replacement: adım 2, 3 resimden 3.
    • Remove the indicated screws (M3 x 16mm Pan Hd. ST T-10 Screws) with screwdriver.
  3. Milwaukee 2704-20 Outer Case Replacement: adım 3, 3 resimden 1. Milwaukee 2704-20 Outer Case Replacement: adım 3, 3 resimden 2. Milwaukee 2704-20 Outer Case Replacement: adım 3, 3 resimden 3.
    • Gently lift the cover off the drill. Be careful not to force it or damage any of the internal components.
    • If the cover doesn't come off easily, check for any clips or latches that may be holding it in place. These can usually be released by pressing them with a small flathead screwdriver.
Sonuç
Unique Linnell
423 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-1, Petersen Spring 2023 UMass Dartmouth, Team 2-1, Petersen Spring 2023 üyesi
UMASSD-PETERSEN-S23S2G1
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 170
