Ana içeriğe geç
Milwaukee 2704-20 Trigger Replacement
Neye ihtiyacın var
  1. Milwaukee 2704-20 Trigger Replacement, Outer Case: adım 1, 2 resimden 1. Milwaukee 2704-20 Trigger Replacement, Outer Case: adım 1, 2 resimden 2.
    • Remove the battery from the drill.
  2. Milwaukee 2704-20 Trigger Replacement: adım 2, 3 resimden 1. Milwaukee 2704-20 Trigger Replacement: adım 2, 3 resimden 2. Milwaukee 2704-20 Trigger Replacement: adım 2, 3 resimden 3.
    • Remove the indicated screws (M3 x 16mm Pan Hd. ST T-10 Screws) with screwdriver.
  3. Milwaukee 2704-20 Trigger Replacement: adım 3, 3 resimden 1. Milwaukee 2704-20 Trigger Replacement: adım 3, 3 resimden 2. Milwaukee 2704-20 Trigger Replacement: adım 3, 3 resimden 3.
    • Gently lift the cover off the drill. Be careful not to force it or damage any of the internal components.
    • If the cover doesn't come off easily, check for any clips or latches that may be holding it in place. These can usually be released by pressing them with a small flathead screwdriver.
  4. Milwaukee 2704-20 Trigger Replacement, Trigger: adım 4, 2 resimden 1. Milwaukee 2704-20 Trigger Replacement, Trigger: adım 4, 2 resimden 2.
    • Desolder the two solder joints on the trigger assembly.
    • USE CAUTION! Soldering irons get extremely hot, as will everything they make prolonged contact with.
  5. Milwaukee 2704-20 Trigger Replacement: adım 5, 2 resimden 1. Milwaukee 2704-20 Trigger Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using tweezers, remove the header connector.
    • To avoid damage, be careful replicating this step in both the removal and replacement processes.
  6. Milwaukee 2704-20 Trigger Replacement: adım 6, 1 resimden 1.
    • Remove the trigger mechanism entirely.
Sonuç
Brandon Farquharson
153 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-1, Petersen Spring 2023 UMass Dartmouth, Team 2-1, Petersen Spring 2023 üyesi
UMASSD-PETERSEN-S23S2G1
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 85
Her zaman: 615
