Giriş
Is your Angle Grinder’s trigger not working? If so, here is the guide to fix the problem with a simple change of a trigger assembly. The trigger assembly is the one of the main components for the grinder. Basically, a squeeze of the trigger turns on the electric motor inside thus making the tool run. Without a fully functioning trigger, the machine would not be able to turn on. All you need to make the repair is a Torx T20 and a Torx T10 screwdriver to remove two different types of screws involved with this replacement.
Neye ihtiyacın var
Using a Torx T20 screwdriver, unscrew the four 16mm screws from the case.
Switch to the Torx T10 screwdriver, and remove the last 16mm screw from the hilt.
Bir başkası bu kılavuzu tamamladı.
