Ana içeriğe geç
Milwaukee 2780-20 Trigger Assembly Replacement
Neye ihtiyacın var
  1. Milwaukee 2780-20 Trigger Assembly Replacement, Trigger Assembly: adım 1, 3 resimden 1. Milwaukee 2780-20 Trigger Assembly Replacement, Trigger Assembly: adım 1, 3 resimden 2. Milwaukee 2780-20 Trigger Assembly Replacement, Trigger Assembly: adım 1, 3 resimden 3.
    • Using a Torx T20 screwdriver, unscrew the four 16mm screws from the case.
    • Switch to the Torx T10 screwdriver, and remove the last 16mm screw from the hilt.
  2. Milwaukee 2780-20 Trigger Assembly Replacement: adım 2, 3 resimden 1. Milwaukee 2780-20 Trigger Assembly Replacement: adım 2, 3 resimden 2. Milwaukee 2780-20 Trigger Assembly Replacement: adım 2, 3 resimden 3.
    • Using the Torx T20 screwdriver, unscrew the four 28mm screws located at the bottom (and top) of the gearcase assembly.
    • Remove the two 12mm screws with a Torx T20 screwdriver in order to get to the others.
  3. Milwaukee 2780-20 Trigger Assembly Replacement: adım 3, 1 resimden 1.
    • Pull apart the housing handles.
  4. Milwaukee 2780-20 Trigger Assembly Replacement: adım 4, 3 resimden 1. Milwaukee 2780-20 Trigger Assembly Replacement: adım 4, 3 resimden 2. Milwaukee 2780-20 Trigger Assembly Replacement: adım 4, 3 resimden 3.
    • Lift the trigger assembly off of its mount.
    • Dispose of the old trigger assembly and install the new one.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 22
Her zaman: 1,218
