Ana içeriğe geç
Milwaukee 5262-21 Fan Baffle Replacement
Neye ihtiyacın var
  1. Milwaukee 5262-21 Fan Baffle Replacement, Housing Assembly: adım 1, 1 resimden 1.
    • Remove the ten 19mm T20 Torx screws shown in red.
  2. Milwaukee 5262-21 Fan Baffle Replacement: adım 2, 1 resimden 1.
    • Remove the red Housing Assembly by lifting it up off of the tool.
  3. Milwaukee 5262-21 Fan Baffle Replacement, Fan Baffle: adım 3, 2 resimden 1. Milwaukee 5262-21 Fan Baffle Replacement, Fan Baffle: adım 3, 2 resimden 2.
    • Now the two 10mm T-10 screws shown in red can be removed.
    • Next, remove the two 10mm T-10 screws located on the other side of the tool shown in orange.
  4. Milwaukee 5262-21 Fan Baffle Replacement: adım 4, 2 resimden 1. Milwaukee 5262-21 Fan Baffle Replacement: adım 4, 2 resimden 2.
    • Using the metal spudger, remove each brush holder as shown in the images.
  5. Milwaukee 5262-21 Fan Baffle Replacement: adım 5, 3 resimden 1. Milwaukee 5262-21 Fan Baffle Replacement: adım 5, 3 resimden 2. Milwaukee 5262-21 Fan Baffle Replacement: adım 5, 3 resimden 3.
    • Remove the four 37mm T-20 screws shown in red. These screws attach the gear housing to the motor housing.
  6. Milwaukee 5262-21 Fan Baffle Replacement: adım 6, 2 resimden 1. Milwaukee 5262-21 Fan Baffle Replacement: adım 6, 2 resimden 2.
    • After removing the four screws, pull apart the the two sections.
  7. Milwaukee 5262-21 Fan Baffle Replacement: adım 7, 2 resimden 1. Milwaukee 5262-21 Fan Baffle Replacement: adım 7, 2 resimden 2.
    • Remove the four 12mm screws with a T-15 Torx screwdriver shown in red.
    • These screws hold the fan baffle in place.
  8. Milwaukee 5262-21 Fan Baffle Replacement: adım 8, 2 resimden 1. Milwaukee 5262-21 Fan Baffle Replacement: adım 8, 2 resimden 2.
    • Remove the fan baffle by pulling it out.
Sonuç
Andrew Floyd
277 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G3, Botvin Spring 2019 UMass Dartmouth, Team S1-G3, Botvin Spring 2019 üyesi
UMASSD-BOTVIN-S19S1G3
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 657
