Ana içeriğe geç
Milwaukee 5262-21 Power Cord Replacement
Neye ihtiyacın var
  1. Milwaukee 5262-21 Power Cord Replacement, Housing Assembly: adım 1, 1 resimden 1.
    • Remove the ten 19mm T20 Torx screws shown in red.
  2. Milwaukee 5262-21 Power Cord Replacement: adım 2, 1 resimden 1.
    • Remove the red Housing Assembly by lifting it up off of the tool.
  3. Milwaukee 5262-21 Power Cord Replacement, Power Cord: adım 3, 2 resimden 1. Milwaukee 5262-21 Power Cord Replacement, Power Cord: adım 3, 2 resimden 2.
    • Remove the two 11.5mm T-15 screws shown in red.
  4. Milwaukee 5262-21 Power Cord Replacement: adım 4, 3 resimden 1. Milwaukee 5262-21 Power Cord Replacement: adım 4, 3 resimden 2. Milwaukee 5262-21 Power Cord Replacement: adım 4, 3 resimden 3.
    • Follow the black and white cord to the trigger.
    • On the trigger there are two small bolts that you have to loosen.
    • Loosen them slightly with a H - 1.5 bit.
  5. Milwaukee 5262-21 Power Cord Replacement: adım 5, 3 resimden 1. Milwaukee 5262-21 Power Cord Replacement: adım 5, 3 resimden 2. Milwaukee 5262-21 Power Cord Replacement: adım 5, 3 resimden 3.
    • Once the bolts are loose you can pull both cords straight out from the trigger.
    • Pull the cable from the chassis and put it to the side and it has been successfully removed.
Sonuç
Adrien Andrade-Cain
181 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G3, Botvin Spring 2019 UMass Dartmouth, Team S1-G3, Botvin Spring 2019 üyesi
UMASSD-BOTVIN-S19S1G3
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 333
