Ana içeriğe geç
Milwaukee 5262-21 Reduction Gear Assembly Replacement
Neye ihtiyacın var
  1. Milwaukee 5262-21 Reduction Gear Assembly Replacement, Housing Assembly: adım 1, 1 resimden 1.
    • Remove the ten 19mm T20 Torx screws shown in red.
  2. Milwaukee 5262-21 Reduction Gear Assembly Replacement: adım 2, 1 resimden 1.
    • Remove the red Housing Assembly by lifting it up off of the tool.
  3. Milwaukee 5262-21 Reduction Gear Assembly Replacement, Reduction Gear Assembly: adım 3, 2 resimden 1. Milwaukee 5262-21 Reduction Gear Assembly Replacement, Reduction Gear Assembly: adım 3, 2 resimden 2.
    • Remove the two 10mm T-10 Torx screws that attach the top brush holders to the motor housing.
    • Remove the two 10mm T-10 Torx screws that attach the bottom brush holders to the motor housing.
  4. Milwaukee 5262-21 Reduction Gear Assembly Replacement: adım 4, 2 resimden 1. Milwaukee 5262-21 Reduction Gear Assembly Replacement: adım 4, 2 resimden 2.
    • Using a metal spudger, pry off each brush holder.
  5. Milwaukee 5262-21 Reduction Gear Assembly Replacement: adım 5, 3 resimden 1. Milwaukee 5262-21 Reduction Gear Assembly Replacement: adım 5, 3 resimden 2. Milwaukee 5262-21 Reduction Gear Assembly Replacement: adım 5, 3 resimden 3.
    • Remove the four 37mm T20 Torx screws shown in red.
  6. Milwaukee 5262-21 Reduction Gear Assembly Replacement: adım 6, 2 resimden 1. Milwaukee 5262-21 Reduction Gear Assembly Replacement: adım 6, 2 resimden 2.
    • Pull the front portion of the tool out from the motor housing.
  7. Milwaukee 5262-21 Reduction Gear Assembly Replacement: adım 7, 3 resimden 1. Milwaukee 5262-21 Reduction Gear Assembly Replacement: adım 7, 3 resimden 2. Milwaukee 5262-21 Reduction Gear Assembly Replacement: adım 7, 3 resimden 3.
    • Remove the two 11.5mm T10 Torx screws shown in red.
  8. Milwaukee 5262-21 Reduction Gear Assembly Replacement: adım 8, 2 resimden 1. Milwaukee 5262-21 Reduction Gear Assembly Replacement: adım 8, 2 resimden 2.
    • Pull the 120V armature assembly out of the diaphragm assembly.
  9. Milwaukee 5262-21 Reduction Gear Assembly Replacement: adım 9, 2 resimden 1. Milwaukee 5262-21 Reduction Gear Assembly Replacement: adım 9, 2 resimden 2.
    • Using a metal spudger, pry the diaphgram assembly out of the gear case.
  10. Milwaukee 5262-21 Reduction Gear Assembly Replacement: adım 10, 2 resimden 1. Milwaukee 5262-21 Reduction Gear Assembly Replacement: adım 10, 2 resimden 2.
    • Now that you have loosened the diaphragm, you can now pull it out of the gear case.
  11. Milwaukee 5262-21 Reduction Gear Assembly Replacement: adım 11, 3 resimden 1. Milwaukee 5262-21 Reduction Gear Assembly Replacement: adım 11, 3 resimden 2. Milwaukee 5262-21 Reduction Gear Assembly Replacement: adım 11, 3 resimden 3.
    • The diaphragm assembly will be lathered in grease. In order to move forward, you may want to give it a wipe down to remove any extra grease.
    • After removing some grease (if needed), remove the two 15mm T20 Torx screws shown in red.
  12. Milwaukee 5262-21 Reduction Gear Assembly Replacement: adım 12, 3 resimden 1. Milwaukee 5262-21 Reduction Gear Assembly Replacement: adım 12, 3 resimden 2. Milwaukee 5262-21 Reduction Gear Assembly Replacement: adım 12, 3 resimden 3.
    • Now pull the reduction gear assembly up and out of the diaphragm.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Payton Parker
534 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G3, Botvin Spring 2019 UMass Dartmouth, Team S1-G3, Botvin Spring 2019 üyesi
UMASSD-BOTVIN-S19S1G3
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 1,440
