Giriş
If your Milwaukee (6130-33) device is producing either loss of power or sound, then this replacement guide will provide you with step-by-step instructions in repairing your device. Necessary tools for the guide include a TR10 screwdriver and a set of pliers.
The carbon brush lock is responsible for maintaining the motor during usage. Worn or faulty brushes can damage both the interior casing and the brush casing. Regular maintenance and replacement of the brushes are important to maintain optimal performance and prevent damage.
Neye ihtiyacın var
Hold the device with the cord facing upwards and the bottom side facing down.
Remove the 4 mm TR20 Torx screws from the exterior case.
Remove both 3.5 mm TR10 Torx screws from the carbon brush locks.
