Ana içeriğe geç
Milwaukee Hex Impact Driver 2656-20 Case Disassembly
Neye ihtiyacın var
  1. Milwaukee Hex Impact Driver 2656-20 Case  Disassembly, Battery: adım 1, 2 resimden 1. Milwaukee Hex Impact Driver 2656-20 Case  Disassembly, Battery: adım 1, 2 resimden 2.
    • Squeeze the red buttons on the battery.
    • While squeezing the red buttons, slide the battery forward and out to remove it from the device.
    FixBot'a Sor
    Yorum Ekle
  2. Milwaukee Hex Impact Driver 2656-20 Case  Disassembly, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: adım 2, 2 resimden 1. Milwaukee Hex Impact Driver 2656-20 Case  Disassembly, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: adım 2, 2 resimden 2.
    • Lay the impact driver on its side.
    • Remove eight 16 mm and a single 19 mm screws using the T10 Torx Screwdriver.
    • Separate the two halves by pulling up on the top half.
    • Make sure that the half with the screw heads Is facing up during this process. This will ensure that the components do not fall out.
    • Lay the top half to the side.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 44
Her zaman: 3,043
