Ana içeriğe geç
Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement
Neye ihtiyacın var
  1. Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement, Battery: adım 1, 2 resimden 1. Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement, Battery: adım 1, 2 resimden 2.
    • Squeeze the red buttons on the battery.
    • While squeezing the red buttons, slide the battery forward and out to remove it from the device.
  2. Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: adım 2, 2 resimden 1. Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: adım 2, 2 resimden 2.
    • Lay the impact driver on its side.
    • Remove eight 16 mm and a single 19 mm screws using the T10 Torx Screwdriver.
    • Separate the two halves by pulling up on the top half.
    • Make sure that the half with the screw heads Is facing up during this process. This will ensure that the components do not fall out.
    • Lay the top half to the side.
  3. Milwaukee Hex Impact Driver 2656-20 Forward/Reverse switch Replacement, Forward/Reverse Switch: adım 3, 1 resimden 1.
    • Gently move the trigger assembly out of the way and remove the switch from the device.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 29
Her zaman: 1,710
