Ana içeriğe geç
Milwaukee Hex Impact Driver 2750-20 Output Shaft Bearing Replacement
Neye ihtiyacın var
  1. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement, Outer Casing: adım 1, 1 resimden 1.
    • Remove the five T9 15.5 mm screws.
    • Remove the single T9 19.5mm screw.
    • Remove the two T9 37mm screws.
  2. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: adım 2, 1 resimden 1.
    • Remove the drill casing to expose the drill's interior parts.
  3. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement, Output Shaft Bearing: adım 3, 1 resimden 1.
    • Once the interior is open locate the output shaft driver pictured at the left of the screen.
  4. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: adım 4, 3 resimden 1. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: adım 4, 3 resimden 2. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: adım 4, 3 resimden 3.
    • Lift the driver head and motor assembly directly out of the outer casing.
    • Pull the driver head away from the motor assembly, separating the two.
  5. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: adım 5, 3 resimden 1. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: adım 5, 3 resimden 2. Milwaukee Hex Impact Driver 2750-20  Output Shaft Bearing Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the fan and the drive shaft assembly from the motor core assembly.
    • Using a pair of tweezers, remove the retaining ring.
    • Remove the old bearing and reinstall the new retaining clip.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 586
