Ana içeriğe geç
Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement
Neye ihtiyacın var
  1. Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement, Outer Casing: adım 1, 1 resimden 1.
    • Remove the five T9 15.5 mm screws.
    • Remove the single T9 19.5mm screw.
    • Remove the two T9 37mm screws.
  2. Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement: adım 2, 1 resimden 1.
    • Remove the drill casing to expose the drill's interior parts.
  3. Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement, Chuck Drive Shaft: adım 3, 3 resimden 1. Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement, Chuck Drive Shaft: adım 3, 3 resimden 2. Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement, Chuck Drive Shaft: adım 3, 3 resimden 3.
    • Pulling directly outward, remove the driver head from the motor assembly by picking it up out of the casing.
  4. Milwaukee Hex Impact Driver 2750-20 Chuck Drive Shaft Replacement: adım 4, 1 resimden 1.
    • Remove the drive shaft assembly from the motor coils.
    • There will be resistance when removing the drive shaft as there is magnetism working against you.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 748
