Ana içeriğe geç
Milwaukee Hex Impact Driver 2750-20 Directional Switch Replacement
Neye ihtiyacın var
  1. Milwaukee Hex Impact Driver 2750-20 Directional Switch Replacement, Outer Casing: adım 1, 1 resimden 1.
    • Remove the five T9 15.5 mm screws.
    • Remove the single T9 19.5mm screw.
    • Remove the two T9 37mm screws.
  2. Milwaukee Hex Impact Driver 2750-20 Directional Switch Replacement: adım 2, 1 resimden 1.
    • Remove the drill casing to expose the drill's interior parts.
  3. Milwaukee Hex Impact Driver 2750-20 Directional Switch Replacement, Directional Switch: adım 3, 3 resimden 1. Milwaukee Hex Impact Driver 2750-20 Directional Switch Replacement, Directional Switch: adım 3, 3 resimden 2. Milwaukee Hex Impact Driver 2750-20 Directional Switch Replacement, Directional Switch: adım 3, 3 resimden 3.
    • Remove the trigger assembly completely.
    • Remove the directional switch by lifting upward using a pair of tweezers, clearing the alignment pole on the trigger assembly.
    • Insert a new directional switch by aligning the hole on the switch with the pole on the trigger.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 905
