Giriş
The Milwaukee Hex Impact Driver 2750-20 contains an outer casing that must be removed to change all interior parts. This is a prerequisite guide to removing the outer case to make repairs on the device. The following guide provides the necessary tools as well as steps to replacing the outer casing in an easy and efficient manner.
Neye ihtiyacın var
Remove the five T9 15.5 mm screws.
Remove the single T9 19.5mm screw.
Remove the two T9 37mm screws.
