Ana içeriğe geç
Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement
Neye ihtiyacın var
  1. Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement, Milwaukee Hex Impact Driver 2753-20 Cover Removal: adım 1, 1 resimden 1.
    • Using the Torx T10 screwdriver, remove the six 17 mm screws on the outside of the handle.
    • Remove the two 40 mm Torx T10 screws near the bottom of the cover.
  2. Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement: adım 2, 2 resimden 1. Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement: adım 2, 2 resimden 2.
    • Carefully remove the cover.
    • If there is buildup from sawdust or sediment it might be a little difficult to take apart.
  3. Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement, Reverse Button: adım 3, 2 resimden 1. Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement, Reverse Button: adım 3, 2 resimden 2.
    • Locate the black forward/reverse button underneath the chuck.
    • Pull the button gently towards you to remove it from the trigger assembly.
  4. Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement: adım 4, 1 resimden 1.
    • Using replacement part NO. 45-24-D013 (forward/reverse shuttle), follow the steps of this guide in reverse order.
Sonuç
Alex Larson
243 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 25
Her zaman: 843
