Ana içeriğe geç
Milwaukee Hole Hawg 1675-1 Field Replacement
Neye ihtiyacın var
  1. Milwaukee Hole Hawg 1675-1 Field Replacement, Motor Brushes: adım 1, 1 resimden 1.
    • Ensure that the drill is unplugged.
    • Position the drill so that it is on its side.
  2. Milwaukee Hole Hawg 1675-1 Field Replacement: adım 2, 3 resimden 1. Milwaukee Hole Hawg 1675-1 Field Replacement: adım 2, 3 resimden 2. Milwaukee Hole Hawg 1675-1 Field Replacement: adım 2, 3 resimden 3.
    • Remove the brush cap with a flathead screwdriver.
  3. Milwaukee Hole Hawg 1675-1 Field Replacement: adım 3, 2 resimden 1. Milwaukee Hole Hawg 1675-1 Field Replacement: adım 3, 2 resimden 2.
    • Pry up on the copper brush holder with a screwdriver or spudger.
    • Continue lifting up the copper brush holder to remove the brush.
    • Repeat on the opposite side.
  4. Milwaukee Hole Hawg 1675-1 Field Replacement, Field: adım 4, 2 resimden 1. Milwaukee Hole Hawg 1675-1 Field Replacement, Field: adım 4, 2 resimden 2.
    • Position the the drill upright and remove the four 19mm Torx T15 screws securing the motor cover.
  5. Milwaukee Hole Hawg 1675-1 Field Replacement: adım 5, 3 resimden 1. Milwaukee Hole Hawg 1675-1 Field Replacement: adım 5, 3 resimden 2. Milwaukee Hole Hawg 1675-1 Field Replacement: adım 5, 3 resimden 3.
    • Remove the motor cover and withdraw the armature.
    • Take note to not lose the washer that sits on top of the armature.
  6. Milwaukee Hole Hawg 1675-1 Field Replacement: adım 6, 2 resimden 1. Milwaukee Hole Hawg 1675-1 Field Replacement: adım 6, 2 resimden 2.
    • Remove the black insulator ring.
    • Remove the two 45mm Torx T15 screws securing the field to the drill.
  7. Milwaukee Hole Hawg 1675-1 Field Replacement: adım 7, 3 resimden 1. Milwaukee Hole Hawg 1675-1 Field Replacement: adım 7, 3 resimden 2. Milwaukee Hole Hawg 1675-1 Field Replacement: adım 7, 3 resimden 3.
    • Position drill on its side.
    • Remove the four 19mm Torx T15 screws.
    • Remove the two 25mm Torx T27 screws.
    • Remove the top portion of the handle.
  8. Milwaukee Hole Hawg 1675-1 Field Replacement: adım 8, 2 resimden 1. Milwaukee Hole Hawg 1675-1 Field Replacement: adım 8, 2 resimden 2.
    • Lift the switch up and away to allow room to work.
    • Uncrimp the wire connector on the yellow field wire attached to the switch to disconnect it.
  9. Milwaukee Hole Hawg 1675-1 Field Replacement: adım 9, 1 resimden 1.
    • Lift the field out of the device, feeding the yellow wire through the handle.
Sonuç
Colby Green
183 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 19
Her zaman: 706
