Ana içeriğe geç
Milwaukee Hole Hawg 1675-1 Switch Replacement
Neye ihtiyacın var
  1. Milwaukee Hole Hawg 1675-1 Switch Replacement, Switch: adım 1, 1 resimden 1.
    • Ensure that the drill is unplugged.
    • Position the drill so that it is on its side.
  2. Milwaukee Hole Hawg 1675-1 Switch Replacement: adım 2, 2 resimden 1. Milwaukee Hole Hawg 1675-1 Switch Replacement: adım 2, 2 resimden 2.
    • Remove the four 19mm Torx T15 screws.
    • Remove the two 25mm Torx T27 screw.
  3. Milwaukee Hole Hawg 1675-1 Switch Replacement: adım 3, 3 resimden 1. Milwaukee Hole Hawg 1675-1 Switch Replacement: adım 3, 3 resimden 2. Milwaukee Hole Hawg 1675-1 Switch Replacement: adım 3, 3 resimden 3.
    • Remove the top portion of the handle.
    • Pay special attention to where each wire connects.
    • Lift up on the switch and disconnect the wires.
    • Use a #0 flathead screwdriver to release tension on the wires.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 24
Her zaman: 1,337
