Ana içeriğe geç
Milwaukee Impact Wrench 9070-20 Motor Field Winding Replacement
Neye ihtiyacın var
  1. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement, Motor Field Winding: adım 1, 3 resimden 1. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement, Motor Field Winding: adım 1, 3 resimden 2. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement, Motor Field Winding: adım 1, 3 resimden 3.
    • Ensure that the device is unplugged from any power source to avoid electrical shock.
    • Flip the device and remove four 18mm screws using a T20 Torx screwdriver.
    • Remove four 14mm screws using a T20 Torx screwdriver.
  2. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: adım 2, 3 resimden 1. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: adım 2, 3 resimden 2. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: adım 2, 3 resimden 3.
    • Remove the four screws on each corner of the gear box assembly using a T-20 Screwdriver.
    • Use a plastic opening tool, slide out the gear box assembly away from the main body.
  3. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: adım 3, 3 resimden 1. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: adım 3, 3 resimden 2. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: adım 3, 3 resimden 3.
    • Separate the top half of the clam shell from the tool.
    • Remove the gearbox assembly by sliding it forward and set it aside.
    • Abrupt pulling may damage the motor brushes. Please remove it with caution.
    • The motor brushes may need to be compressed to help with the removal of the gearbox assembly.
  4. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: adım 4, 3 resimden 1. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: adım 4, 3 resimden 2. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: adım 4, 3 resimden 3.
    • Disconnect the black AC wire from the brown field wire.
    • Disconnect the black field wire from the switch.
  5. Milwaukee Impact Wrench 9070-20 Motor Field Winding  Replacement: adım 5, 1 resimden 1.
    • Pull straight up on the field winding to remove it from the body.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 394
