Ana içeriğe geç
Milwaukee Impact Wrench 9070-20 Power Cord Replacement
Neye ihtiyacın var
  1. Milwaukee Impact Wrench 9070-20 Power Cord Replacement, Power Cord: adım 1, 3 resimden 1. Milwaukee Impact Wrench 9070-20 Power Cord Replacement, Power Cord: adım 1, 3 resimden 2. Milwaukee Impact Wrench 9070-20 Power Cord Replacement, Power Cord: adım 1, 3 resimden 3.
    • Ensure that the device is unplugged from any power source to avoid electrical shock.
    • Flip the device and remove four 18mm screws using the T20 Torx screwdriver.
    • Remove the four 14mm screws using the same screwdriver.
  2. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: adım 2, 3 resimden 1. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: adım 2, 3 resimden 2. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: adım 2, 3 resimden 3.
    • Hold the device so the gray part faces directly towards you.
    • Remove the four screws on the sides using the T20 Torx screwdriver.
    • After removing all screws, use a small plastic pry bar to slide the gearbox assembly forward slightly.
  3. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: adım 3, 2 resimden 1. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: adım 3, 2 resimden 2.
    • Gently remove the upper clam shell from the device.
    • Lift a black colored power cord from its mount at the bottom of the device, so it can move freely.
  4. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: adım 4, 2 resimden 1. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: adım 4, 2 resimden 2.
    • Disconnect the brown field winding wire from the white ac power cord wire.
  5. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: adım 5, 2 resimden 1. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: adım 5, 2 resimden 2.
    • Disconnect the black ac power wire from the connector on the bottom of the forward / reverse switch.
    • Remove the AC power cord and replace it with a new one.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 361
