Ana içeriğe geç
Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement
Neye ihtiyacın var
  1. Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement, Rear Motor Bearing: adım 1, 3 resimden 1. Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement, Rear Motor Bearing: adım 1, 3 resimden 2. Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement, Rear Motor Bearing: adım 1, 3 resimden 3.
    • Ensure that the device is unplugged from any power source to avoid electrical shock.
    • Flip the device, making the gray part face to the right.
    • Remove four 14mm screws using a T20 Torx screwdriver.
    • Remove four 18mm screws using a T20 Torx screwdriver.
  2. Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: adım 2, 3 resimden 1. Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: adım 2, 3 resimden 2. Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: adım 2, 3 resimden 3.
    • Hold the device so the gearbox assembly faces directly towards you.
    • Remove the four screws using a T20 Torx screwdriver.
    • Using a plastic opening tool, pry the gearbox assembly away from the clam shell.
  3. Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: adım 3, 1 resimden 1.
    • After all necessary screws are removed, gently remove the upper red cover from the device.
    • Remove the gray motor and gearbox assembly.
    • Remove the gearbox gently as to not damage the brushes.
  4. Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: adım 4, 3 resimden 1. Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: adım 4, 3 resimden 2. Milwaukee Impact Wrench 9070-20 Rear Motor Bearing Replacement: adım 4, 3 resimden 3.
    • Attach a bearing removal tool to the bearing.
    • Tighten the bearing puller until the bearing comes off of the motor shaft.
    • For easier removal, lightly heat the bearing with a propane torch.
    • Heat and then press the replacement bearing onto the shaft.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 27
Her zaman: 639
