Ana içeriğe geç
Milwaukee M12 2407-20 Outer Casing Replacement
Neye ihtiyacın var
  1. Milwaukee M12 2407-20 Outer Casing Replacement, Outer Casing: adım 1, 1 resimden 1.
    • Remove each of the seven 14mm Pan Hd. T-10 ST screws on one side of the housing assembly using the T10 screwdriver.
  2. Milwaukee M12 2407-20 Outer Casing Replacement: adım 2, 1 resimden 1.
    • Remove metal clip located at the base of the drill, where the battery is to be inserted.
    • You may need to use a spudger if the clip is too difficult to remove with your fingers.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 29
Her zaman: 3,212
