Ana içeriğe geç
Milwaukee M12 2407-20 Shuttle Spring Plate Replacement
Neye ihtiyacın var
    1. Milwaukee M12 2407-20 Shuttle Spring Plate Replacement, Outer Casing: adım 1, 1 resimden 1.
      • Remove each of the seven 14mm Pan Hd. T-10 ST screws on one side of the housing assembly using the T10 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Milwaukee M12 2407-20 Shuttle Spring Plate Replacement: adım 2, 1 resimden 1.
      • Remove metal clip located at the base of the drill, where the battery is to be inserted.
      • You may need to use a spudger if the clip is too difficult to remove with your fingers.
      FixBot'a Sor
      Yorum Ekle
    1. Milwaukee M12 2407-20 Shuttle Spring Plate Replacement, Shuttle Spring Plate: adım 3, 3 resimden 1. Milwaukee M12 2407-20 Shuttle Spring Plate Replacement, Shuttle Spring Plate: adım 3, 3 resimden 2. Milwaukee M12 2407-20 Shuttle Spring Plate Replacement, Shuttle Spring Plate: adım 3, 3 resimden 3.
      • Use both hands to lift and remove the gear case assembly from the shell casing.
      • Set the gear case assembly aside.
      FixBot'a Sor
      Yorum Ekle
    2. Milwaukee M12 2407-20 Shuttle Spring Plate Replacement: adım 4, 2 resimden 1. Milwaukee M12 2407-20 Shuttle Spring Plate Replacement: adım 4, 2 resimden 2.
      • Remove the forward/reversing shuttle to gain access to the spring plate.
      FixBot'a Sor
      Yorum Ekle
    3. Milwaukee M12 2407-20 Shuttle Spring Plate Replacement: adım 5, 1 resimden 1.
      • Remove the spring plate and insert replacement spring plate.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 84
Her zaman: 2,038
