Ana içeriğe geç
Milwaukee M12 2407-20 Speed Selector Lever Replacement
Neye ihtiyacın var
  1. Milwaukee M12 2407-20 Speed Selector Lever Replacement, Outer Casing: adım 1, 1 resimden 1.
    • Remove each of the seven 14mm Pan Hd. T-10 ST screws on one side of the housing assembly using the T10 screwdriver.
  2. Milwaukee M12 2407-20 Speed Selector Lever Replacement: adım 2, 1 resimden 1.
    • Remove metal clip located at the base of the drill, where the battery is to be inserted.
    • You may need to use a spudger if the clip is too difficult to remove with your fingers.
  3. Milwaukee M12 2407-20 Speed Selector Lever Replacement, Speed Selector Lever: adım 3, 3 resimden 1. Milwaukee M12 2407-20 Speed Selector Lever Replacement, Speed Selector Lever: adım 3, 3 resimden 2. Milwaukee M12 2407-20 Speed Selector Lever Replacement, Speed Selector Lever: adım 3, 3 resimden 3.
    • Remove the unit from the housing assembly and set the housing assembly aside.
  4. Milwaukee M12 2407-20 Speed Selector Lever Replacement: adım 4, 1 resimden 1.
    • Use a spudger to pry the broken speed selector lever off the assembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 23
Her zaman: 1,808
