Ana içeriğe geç
Milwaukee M12 2457-20 Disassembly
Neye ihtiyacın var
    1. Milwaukee M12 2457-20 Disassembly, Housing: adım 1, 2 resimden 1. Milwaukee M12 2457-20 Disassembly, Housing: adım 1, 2 resimden 2.
      • Unscrew the four M3 x 10 T-10 screws located on the neck.
      FixBot'a Sor
      Yorum Ekle
    2. Milwaukee M12 2457-20 Disassembly: adım 2, 2 resimden 1. Milwaukee M12 2457-20 Disassembly: adım 2, 2 resimden 2.
      • Remove the spring pin from the switch paddle and take off the switch paddle.
      FixBot'a Sor
      Yorum Ekle
    3. Milwaukee M12 2457-20 Disassembly: adım 3, 1 resimden 1.
      • Unscrew the four M2.6 x 14 ST T-8 screws located on the body.
      • Unscrew the M2.6 x 10 ST T-8 screw located underneath the switch paddle.
      FixBot'a Sor
      Yorum Ekle
    4. Milwaukee M12 2457-20 Disassembly: adım 4, 2 resimden 1. Milwaukee M12 2457-20 Disassembly: adım 4, 2 resimden 2.
      • Separate the two housing parts of the tool.
      • Remove the 3/8" yoke assembly and the motor assembly from the tool housing.
      FixBot'a Sor
      Yorum Ekle
    5. Milwaukee M12 2457-20 Disassembly: adım 5, 2 resimden 1. Milwaukee M12 2457-20 Disassembly: adım 5, 2 resimden 2.
      • Remove the drive pin connecting the 3/8" yoke assembly and the motor assembly.
      • Remove the crankshaft, planet gears, carrier assembly, and ring gear from the motor assembly.
      • Be aware that these parts are lubricated with grease.
      FixBot'a Sor
      Yorum Ekle
    6. Milwaukee M12 2457-20 Disassembly: adım 6, 1 resimden 1.
      • You have now successfully dismantled the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Peter Lizotte
183 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G6, O'Connell Fall 2019 UMass Dartmouth, Team S1-G6, O'Connell Fall 2019 üyesi
UMASSD-O'CONNELL-F19S1G6
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 38
Son 30 gün: 178
Her zaman: 3,009
