Ana içeriğe geç
Milwaukee M18 2606-20 Motor Replacement
Neye ihtiyacın var
  1. Milwaukee M18 2606-20 Motor Replacement, Motor: adım 1, 2 resimden 1. Milwaukee M18 2606-20 Motor Replacement, Motor: adım 1, 2 resimden 2.
    • Remove the seven 18 mm screws, using the T3 Torx Screwdriver, from the handle area of the case.
  2. Milwaukee M18 2606-20 Motor Replacement: adım 2, 3 resimden 1. Milwaukee M18 2606-20 Motor Replacement: adım 2, 3 resimden 2. Milwaukee M18 2606-20 Motor Replacement: adım 2, 3 resimden 3.
    • Remove the four 20 mm screws, using the T3 Torx Screwdriver, from the front of the case.
  3. Milwaukee M18 2606-20 Motor Replacement: adım 3, 2 resimden 1. Milwaukee M18 2606-20 Motor Replacement: adım 3, 2 resimden 2.
    • Peel back the sticker at the bottom of the drill handle.
  4. Milwaukee M18 2606-20 Motor Replacement: adım 4, 2 resimden 1. Milwaukee M18 2606-20 Motor Replacement: adım 4, 2 resimden 2.
    • Open the case by sliding the opening tool all the way around the case to pry it apart.
  5. Milwaukee M18 2606-20 Motor Replacement: adım 5, 2 resimden 1. Milwaukee M18 2606-20 Motor Replacement: adım 5, 2 resimden 2.
    • Lift the motor from the casing.
  6. Milwaukee M18 2606-20 Motor Replacement: adım 6, 3 resimden 1. Milwaukee M18 2606-20 Motor Replacement: adım 6, 3 resimden 2. Milwaukee M18 2606-20 Motor Replacement: adım 6, 3 resimden 3.
    • Remove the motor from the case and unscrew the two 8mm screws, using the T3 Torx Screwdriver, on the back of the motor.
    • Remove the connected wires.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 52
Her zaman: 3,265
