Giriş
If the Milwaukee 2605-20 Drill is not allowing orientation switching, follow this guide to inspect and replace the forward/reverse shuttle.
The screws on this device are not easily removed.
Neye ihtiyacın var
Locate the forward/reverse shuttle on the drill, just behind the drill trigger mechanism.
Gently pull the trigger down and remove the damaged fwd/rev shuttle.
Bir başkası bu kılavuzu tamamladı.
