Ana içeriğe geç
Milwaukee Rotary Hammer 260520 D14A 2016 Gear Housing Cover Replacement
Neye ihtiyacın var
  1. Milwaukee Rotary Hammer 260520 D14A 2016 Gear Housing Cover Replacement, Side Handle Case: adım 1, 1 resimden 1.
    • Remove the battery by sliding it from the base.
  2. Milwaukee Rotary Hammer 260520 D14A 2016 Gear Housing Cover Replacement: adım 2, 1 resimden 1.
    • Remove two 20.3 mm screws at the right side of the drill base using a Torx T3 screwdriver.
  3. Milwaukee Rotary Hammer 260520 D14A 2016 Gear Housing Cover Replacement: adım 3, 3 resimden 1. Milwaukee Rotary Hammer 260520 D14A 2016 Gear Housing Cover Replacement: adım 3, 3 resimden 2. Milwaukee Rotary Hammer 260520 D14A 2016 Gear Housing Cover Replacement: adım 3, 3 resimden 3.
    • Remove five 20.3 mm screws on the right side of the handle using a Torx T3 screwdriver.
  4. Milwaukee Rotary Hammer 260520 D14A 2016 Gear Housing Cover Replacement: adım 4, 2 resimden 1. Milwaukee Rotary Hammer 260520 D14A 2016 Gear Housing Cover Replacement: adım 4, 2 resimden 2.
    • Remove four matte 24 mm screws on the crankcase at the rear cover of the drill (connecting the chuck to the handle) using a Torx T3 screwdriver.
  5. Milwaukee Rotary Hammer 260520 D14A 2016 Gear Housing Cover Replacement: adım 5, 1 resimden 1.
    • Remove two 24 mm screws on the housing cover beneath the ventilation slots. These screws point into the drill.
  6. Milwaukee Rotary Hammer 260520 D14A 2016 Gear Housing Cover Replacement: adım 6, 2 resimden 1. Milwaukee Rotary Hammer 260520 D14A 2016 Gear Housing Cover Replacement: adım 6, 2 resimden 2.
    • Using a Torx T5 screwdriver bit, remove two 26.8 mm screws on each side of the drill housing cover, located beneath the ventilation slots. These screws point upwards.
  7. Milwaukee Rotary Hammer 260520 D14A 2016 Gear Housing Cover Replacement: adım 7, 1 resimden 1.
    • Gently pry apart the covers for the drill handle.
  8. Milwaukee Rotary Hammer 260520 D14A 2016 Gear Housing Cover Replacement, Gear Housing Cover: adım 8, 1 resimden 1.
    • Remove the drill assembly from the handle assembly.
  9. Milwaukee Rotary Hammer 260520 D14A 2016 Gear Housing Cover Replacement: adım 9, 1 resimden 1.
    • Gently pry the gear housing cover from the drill assembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sophie Nieder
838 İtibar
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 60
