Ana içeriğe geç
Mini Fridge Hinges Replacement
Neye ihtiyacın var
    1. Mini Fridge Hinges Replacement, Hinges: adım 1, 1 resimden 1.
      • Remove the plug from the outlet. Be sure to grab from the head of the cord.
      FixBot'a Sor
      Yorum Ekle
    2. Mini Fridge Hinges Replacement: adım 2, 1 resimden 1.
      • Remove all food items and shelves from the fridge.
      • Place removed contents to the side and if needed place food items in another fridge temporarily.
      FixBot'a Sor
      Yorum Ekle
    3. Mini Fridge Hinges Replacement: adım 3, 2 resimden 1. Mini Fridge Hinges Replacement: adım 3, 2 resimden 2.
      • Remove the cover to the top hinge to access the hinge and screws. If you are unable to remove the cover with your hands, use a flathead screwdriver to pry it off.
      • Remove the three 20 mm Phillips #1 screws from beneath the cover.
      FixBot'a Sor
      Yorum Ekle
    4. Mini Fridge Hinges Replacement: adım 4, 3 resimden 1. Mini Fridge Hinges Replacement: adım 4, 3 resimden 2. Mini Fridge Hinges Replacement: adım 4, 3 resimden 3.
      • After removing the top hinge, lift the door off of the bottom hinge.
      • Place the door and removed top hinge securely to the side.
      FixBot'a Sor
      Yorum Ekle
    5. Mini Fridge Hinges Replacement: adım 5, 2 resimden 1. Mini Fridge Hinges Replacement: adım 5, 2 resimden 2.
      • Rotate the fridge onto its side.
      • Do not turn the fridge upside down to protect the internal components of the fridge.
      • Remove the two 19 mm Phillips #1 screws and the bottom hinge.
      FixBot'a Sor
      Yorum Ekle
    6. Mini Fridge Hinges Replacement: adım 6, 1 resimden 1.
      • Install the bottom replacement hinge and the two 19 mm Phillips #1 screws.
      • Turn the fridge right side up after the bottom hinge is replaced.
      FixBot'a Sor
      Yorum Ekle
    7. Mini Fridge Hinges Replacement: adım 7, 1 resimden 1.
      • Place the door on the bottom hinge, aligning the hole with the hinge.
      • Install the new top hinge and the three 20 mm Philips #1 screws. Ensure the orientation of the hinge lines up with the door.
      • Tighten as needed until the fridge door opens and closes normally and is not uneven.
      • Replace the top cover and the shelving inside the fridge.
      FixBot'a Sor
      Yorum Ekle
Sonuç
This is a relatively easy fix and is easily repeatable. The replacement parts are inexpensive. We hope this guide extends the life of a mini fridge and expands your understanding of the topic.
Bir başkası bu kılavuzu tamamladı.
1Rehber Yorum
My fridge is not working Death ho gaya h bikul kuch bbi n chal rha h
Prince Singh - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 27
Son 30 gün: 152
Her zaman: 6,292
