Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Mini muscle massage gun cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Mini Muscle Massage Gun, Mini Muscle Massage Gun: adım 1, 3 resimden 1. Mini Muscle Massage Gun, Mini Muscle Massage Gun: adım 1, 3 resimden 2. Mini Muscle Massage Gun, Mini Muscle Massage Gun: adım 1, 3 resimden 3.
    • Device Overview
    • Dimension.
    • Red :98.30mm
    • Orange:116mm
    • Yellow:132.82mm
    • Diameter dimension
    • Red: 48.62mm Diameter
    • Hello 98.8mm Diameter
  2. Mini Muscle Massage Gun, Screws: adım 2, 3 resimden 1. Mini Muscle Massage Gun, Screws: adım 2, 3 resimden 2. Mini Muscle Massage Gun, Screws: adım 2, 3 resimden 3.
    • To remove and disassemble the shell. Follow these instructions.
    • Unscrew all the screw hi lighted in the images.
    • unscrew the cap located at the tip of the device.
  3. Mini Muscle Massage Gun: adım 3, 3 resimden 1. Mini Muscle Massage Gun: adım 3, 3 resimden 2. Mini Muscle Massage Gun: adım 3, 3 resimden 3.
    • Twist and remove the cap located on the back. hi lighted in red.
    • Carefully removed the connector from the PCB
    • Twist and removed the bottom cap. Hi lighted in yellow
  4. Mini Muscle Massage Gun, Dimension internal components.: adım 4, 2 resimden 1. Mini Muscle Massage Gun, Dimension internal components.: adım 4, 2 resimden 2.
    • Battery length.
    • Orange. 66.64mm
    • Yellow: 71.28mm.
    • Battery Diameter.
    • Blue 42mm
    • Massage conector
    • Red:103.13mm
  5. Mini Muscle Massage Gun: adım 5, 3 resimden 1. Mini Muscle Massage Gun: adım 5, 3 resimden 2. Mini Muscle Massage Gun: adım 5, 3 resimden 3.
    • Remove the top shell from the body.
    • Using a screw driver removed part hi lighted in red from the motor
    • Remove screw hi lighted in yellow. Removing this screw will disconnect the motor to the body.
  6. Mini Muscle Massage Gun, Teardown components weight Shell: adım 6, 3 resimden 1. Mini Muscle Massage Gun, Teardown components weight Shell: adım 6, 3 resimden 2. Mini Muscle Massage Gun, Teardown components weight Shell: adım 6, 3 resimden 3.
    • Device handle shell is weighted at 50g . Made from ABS plastic. Injection mold
    • Top shell is weighted at 19g. Made from ABS plastic
    • The tip which is used to hold the shell parts together is weighted at 19g. Made from ABS plastic
  7. Mini Muscle Massage Gun, Teardown components cap: adım 7, 3 resimden 1. Mini Muscle Massage Gun, Teardown components cap: adım 7, 3 resimden 2. Mini Muscle Massage Gun, Teardown components cap: adım 7, 3 resimden 3.
    • Back cap. This include the PCB. is weighted at 14g. Made from ABS plastic.
    • Bottom cap is weighted at 7g. Made from ABS plastic
    • Decoration parts. Non functional weighted at 3g.
  8. Mini Muscle Massage Gun, Internal components.: adım 8, 3 resimden 1. Mini Muscle Massage Gun, Internal components.: adım 8, 3 resimden 2. Mini Muscle Massage Gun, Internal components.: adım 8, 3 resimden 3.
    • Battery. Weighted at 72g. use to power the devic. 1800mAh lithium battery
    • Part connected to the device motor. Use as a connect to various massager head. Weighted at 19g.
    • Device motor. Weighted at 246g.
  9. Mini Muscle Massage Gun, Massage gun interchanagble head: adım 9, 1 resimden 1.
    • Red: Nylon: injection moulded
    • Blue: Rubber: injection moulded
    • Yellow: Eva foam:
  10. Mini Muscle Massage Gun, Teardown complete overview: adım 10, 1 resimden 1.
    • Device design is quite simple which encourage repairability.
    • most part found in the device and be easily replace by purchasing them online
    • 1800mAh high-quality rechargeable lithium battery can be easily replaced online.
    • 30W high-torque motor can also be replace. Purchased online. https://www.hisgifts.com.au/products/sta...
    • Any broken parts of the shell can easily be fixed with 3d printing.
    • most screw can also be found online
Nathasorn Pantratthanamongkol
145 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 69
Her zaman: 432
