Ana içeriğe geç
Minn Kota Trolling Motor Propeller Replacement
Neye ihtiyacın var
  1. Minn Kota Trolling Motor Propeller Replacement, Propeller: adım 1, 1 resimden 1.
    • Clean the propeller and surrounding area so that you’re working with clean materials. This can also help loosen bolts, and make it easier to take apart.
    • Make sure that the trolling motor is disconnected from any power source.
  2. Minn Kota Trolling Motor Propeller Replacement: adım 2, 2 resimden 1. Minn Kota Trolling Motor Propeller Replacement: adım 2, 2 resimden 2.
    • Remove the locking nut by turning in a counterclockwise motion.
  3. Minn Kota Trolling Motor Propeller Replacement: adım 3, 2 resimden 1. Minn Kota Trolling Motor Propeller Replacement: adım 3, 2 resimden 2.
    • Once you've unscrewed the propeller nut, you must also remove the lock washer located directly beneath.
    • If you purchased a new propeller kit, you may replace the old lock washer with the new washer you received in your kit.
  4. Minn Kota Trolling Motor Propeller Replacement: adım 4, 3 resimden 1. Minn Kota Trolling Motor Propeller Replacement: adım 4, 3 resimden 2. Minn Kota Trolling Motor Propeller Replacement: adım 4, 3 resimden 3.
    • Remove the drive pin by pushing on either side so it slides out.
  5. Minn Kota Trolling Motor Propeller Replacement: adım 5, 1 resimden 1.
    • When reinstalling your new propeller, make sure to properly align the drive pin with the base of the new propeller.
Sonuç
Once you have the drive pin lined up correctly with the base of the propeller, repeat steps 1-3 in reverse order. Make sure to utilize your new parts such as the drive pin and lock washer if you purchased a propeller replacement kit to replace your old hardware.
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 38
Her zaman: 5,442
