Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Clean the propeller and surrounding area so that you’re working with clean materials. This can also help loosen bolts, and make it easier to take apart.
Remove the locking nut by turning in a counterclockwise motion.
Once you've unscrewed the propeller nut, you must also remove the lock washer located directly beneath.
Remove the drive pin by pushing on either side so it slides out.
2 farklı kişi bu kılavuzu tamamladı.
