Ana içeriğe geç
Minolta Dimage Xt Capture Button Replacement
Neye ihtiyacın var
  1. Minolta Dimage Xt Capture Button Replacement, Casing: adım 1, 3 resimden 1. Minolta Dimage Xt Capture Button Replacement, Casing: adım 1, 3 resimden 2. Minolta Dimage Xt Capture Button Replacement, Casing: adım 1, 3 resimden 3.
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
    FixBot'a Sor
    Yorum Ekle
  2. Minolta Dimage Xt Capture Button Replacement: adım 2, 3 resimden 1. Minolta Dimage Xt Capture Button Replacement: adım 2, 3 resimden 2. Minolta Dimage Xt Capture Button Replacement: adım 2, 3 resimden 3.
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
    FixBot'a Sor
    Yorum Ekle
  3. Minolta Dimage Xt Capture Button Replacement, Capture Button: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Choosing the front half of the casing, locate the capture button on the top.
    • Using tweezers, apply pressure to the two black hooks (circled in red) while holding the button down from the outside of the case.
    FixBot'a Sor
    Yorum Ekle
  4. Minolta Dimage Xt Capture Button Replacement: adım 4, 1 resimden 1.
    • The button will spring free. The capture device consists of the plastic button and a small metal spring.
    • The button can be reassembled by using the tweezers to place the spring rectangle-side down on the button and snapping the button back into place.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Reassemble the casing by reversing steps 1 and 2.
Megan Milam
56 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 12-4, Benson Spring 2013 Clemson, Team 12-4, Benson Spring 2013 üyesi
CLEM-BENSON-S13S12G4
3 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 28
Her zaman: 943
