Ana içeriğe geç
Minolta Dimage Xt Casing Replacement
Neye ihtiyacın var
  1. Minolta Dimage Xt Casing Replacement, Casing: adım 1, 3 resimden 1. Minolta Dimage Xt Casing Replacement, Casing: adım 1, 3 resimden 2. Minolta Dimage Xt Casing Replacement, Casing: adım 1, 3 resimden 3.
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
    FixBot'a Sor
    Yorum Ekle
  2. Minolta Dimage Xt Casing Replacement: adım 2, 3 resimden 1. Minolta Dimage Xt Casing Replacement: adım 2, 3 resimden 2. Minolta Dimage Xt Casing Replacement: adım 2, 3 resimden 3.
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. The outer casing must be properly in place and screws tight to protect the internal hardware.
Megan Milam
56 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 12-4, Benson Spring 2013 Clemson, Team 12-4, Benson Spring 2013 üyesi
CLEM-BENSON-S13S12G4
3 Üyeler
14 adet Kılavuz yazıldı
1Rehber Yorum
How to reattach the ribbon????
rosybrier - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 43
Her zaman: 847
