Tehlike
Tehlikeli Olma Potansiyeli Var
Bu talimat doğru şekilde uygulanmazsa yaralanma meydana gelebilir. Dikkatli olun ve tüm uyarıları takip edin.
Tehlike
Giriş
In the event that the flash is not working properly due to internal issues and not settings, it is possible to replace the battery to restore function to the flash.
Parçalar
Hiçbir parçaya gerek yok.
  1. Locate and remove the silver screws on each side of the camera. Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws. Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  3. Then, carefully pry apart the front and back outer casing away from the internal components. Be aware of the ribbon wire that will disconnect when the casing is detached. Be aware of the ribbon wire that will disconnect when the casing is detached.
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
  4. On the front side of the camera, locate the flash battery holder. Lift the housing and remove the battery.
    • On the front side of the camera, locate the flash battery holder.
    • Lift the housing and remove the battery.
    • After removing the battery, clip the wires and solder the replacement battery.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Qqq
19 İtibar
1 Kılavuz yazıldı
Bir Yorum
Its a cap not a battery :D
Eigirdas Gedgaudas - Yanıt
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 2
Son 30 Gün: 5
Her zaman: 609
