Giriş
The flashbulb and casing are one component located at the top of the camera. A replacement will be the whole component and not each of the parts separately.
Parçalar
Hiçbir parçaya gerek yok.
  1. Locate and remove the silver screws on each side of the camera. Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws. Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Then, carefully pry apart the front and back outer casing away from the internal components. Be aware of the ribbon wire that will disconnect when the casing is detached. Be aware of the ribbon wire that will disconnect when the casing is detached.
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
  3. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. Remove 2mm screws connecting the flash housing to the main components of the camera. Use a Philips #00 screwdriver to remove the black 2.0mm (4 instances) screws .
    • Remove 2mm screws connecting the flash housing to the main components of the camera.
    • Use a Philips #00 screwdriver to remove the black 2.0mm (4 instances) screws .
  5. Use the spudger to push the black plastic hooks through the circuit board to release the flash housing. Once the screws have been removed, pull the circuit board away from the body of the camera. Wires will keep it from completely detaching.
    • Use the spudger to push the black plastic hooks through the circuit board to release the flash housing.
    • Once the screws have been removed, pull the circuit board away from the body of the camera.
    • Wires will keep it from completely detaching.
    • Pull the housing away from the circuit board.
Sonuç
To reassemble device, follow steps in reverse order. This will require the reattachment of wires from the camera to the flashbulb casing.
Keith Sechrist
22 İtibar
2 adet Kılavuz yazıldı
Takım
Clemson, Team 12-4, Benson Spring 2013 Clemson, Team 12-4, Benson Spring 2013 üyesi
CLEM-BENSON-S13S12G4
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 2
Son 30 Gün: 2
Her zaman: 310
