Ana içeriğe geç
Minolta Dimage Xt Flashbulb and Housing Replacement
Neye ihtiyacın var
  1. Minolta Dimage Xt Flashbulb and Housing Replacement, Casing: adım 1, 3 resimden 1. Minolta Dimage Xt Flashbulb and Housing Replacement, Casing: adım 1, 3 resimden 2. Minolta Dimage Xt Flashbulb and Housing Replacement, Casing: adım 1, 3 resimden 3.
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Minolta Dimage Xt Flashbulb and Housing Replacement: adım 2, 3 resimden 1. Minolta Dimage Xt Flashbulb and Housing Replacement: adım 2, 3 resimden 2. Minolta Dimage Xt Flashbulb and Housing Replacement: adım 2, 3 resimden 3.
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
  3. Minolta Dimage Xt Flashbulb and Housing Replacement, Flashbulb and Housing: adım 3, 2 resimden 1. Minolta Dimage Xt Flashbulb and Housing Replacement, Flashbulb and Housing: adım 3, 2 resimden 2.
    • Remove 2mm screws connecting the flash housing to the main components of the camera.
    • Use a Philips #00 screwdriver to remove the black 2.0mm (4 instances) screws .
  4. Minolta Dimage Xt Flashbulb and Housing Replacement: adım 4, 3 resimden 1. Minolta Dimage Xt Flashbulb and Housing Replacement: adım 4, 3 resimden 2. Minolta Dimage Xt Flashbulb and Housing Replacement: adım 4, 3 resimden 3.
    • Use the spudger to push the black plastic hooks through the circuit board to release the flash housing.
    • Once the screws have been removed, pull the circuit board away from the body of the camera.
    • Wires will keep it from completely detaching.
    • Pull the housing away from the circuit board.
Sonuç
To reassemble device, follow steps in reverse order. This will require the reattachment of wires from the camera to the flashbulb casing.
Keith Sechrist
22 İtibar
2 adet Kılavuz yazıldı
Ekip
Clemson, Team 12-4, Benson Spring 2013 Clemson, Team 12-4, Benson Spring 2013 üyesi
CLEM-BENSON-S13S12G4
3 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 638
