Ana içeriğe geç
Minolta Dimage Xt LCD Screen Disassembly
Neye ihtiyacın var
  1. Minolta Dimage Xt LCD Screen Disassembly, Casing: adım 1, 3 resimden 1. Minolta Dimage Xt LCD Screen Disassembly, Casing: adım 1, 3 resimden 2. Minolta Dimage Xt LCD Screen Disassembly, Casing: adım 1, 3 resimden 3.
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Minolta Dimage Xt LCD Screen Disassembly: adım 2, 3 resimden 1. Minolta Dimage Xt LCD Screen Disassembly: adım 2, 3 resimden 2. Minolta Dimage Xt LCD Screen Disassembly: adım 2, 3 resimden 3.
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
  3. Minolta Dimage Xt LCD Screen Disassembly, LCD Screen: adım 3, 1 resimden 1.
    • The LCD screen has wires connecting it to the rest of the camera. A bracket holds the LCD in place, so there are no screws beyond this point.
    • The screen also has a ribbon wire connected at the bottom of the screen.
  4. Minolta Dimage Xt LCD Screen Disassembly: adım 4, 2 resimden 1. Minolta Dimage Xt LCD Screen Disassembly: adım 4, 2 resimden 2.
    • Detach the connector at the bottom from the LCD screen.
    • Starting from the side or a corner gently slide the spudger underneath the screen.
    • Press the tip of the spudger down as far is you can and slowly pry the LCD screen away from the bracket.
  5. Minolta Dimage Xt LCD Screen Disassembly: adım 5, 1 resimden 1.
    • The screen is not detached. Wires are still connecting the screen to the camera at the bottom corners, but it is removed from the bracket.
    • Check to make sure the wires are connected, so it will receive proper power supply.
    • To remove the bracket from the LCD screen, remove two 1.5 mm screws using the Phillips #00 screwdriver.
Sonuç
To install a new LCD screen you will have to reconnect the wires and properly place them in the bracket. Make sure to reattach the ribbon wire before finishing repairs.
Bir başkası bu kılavuzu tamamladı.
Keith Sechrist
22 İtibar
2 adet Kılavuz yazıldı
Ekip
Clemson, Team 12-4, Benson Spring 2013 Clemson, Team 12-4, Benson Spring 2013 üyesi
CLEM-BENSON-S13S12G4
3 Üyeler
14 adet Kılavuz yazıldı
Bir Yorum
Great procedure, thank you.
Do you know where I can buy the LCD replacement part?
I have a Konica Minolta Dimage X1 8.0 MP
mscir - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 974
