Ana içeriğe geç
Minolta Maxxum QTSI Tripod Mount Replacement
Neye ihtiyacın var
  1. Minolta Maxxum QTSI Tripod Mount Replacement, Tripod Mount: adım 1, 1 resimden 1.
    • With a screwdriver, remove the (7) black Phillips #00 5.0mm screws on the bottom of the camera.
    • The screws are located on the outer edge of the bottom panel.
    • Be careful when removing the screws from the panel because they are easy to lose.
  2. Minolta Maxxum QTSI Tripod Mount Replacement: adım 2, 2 resimden 1. Minolta Maxxum QTSI Tripod Mount Replacement: adım 2, 2 resimden 2.
    • Once all the screws are removed, the panel should easily come off.
    • Remove the bottom panel of the camera by placing your index finger and thumb on the outer edges of the panel.
    • Pull the bottom panel towards you, it should come off easily.
  3. Minolta Maxxum QTSI Tripod Mount Replacement: adım 3, 1 resimden 1.
    • The tripod socket is visible when the bottom panel is removed.
    • Remove the (3) black Phillips #00 6.25mm screws from the tripod socket.
    • When the screws are removed, the tripod socket is free and can easily be lost.
  4. Minolta Maxxum QTSI Tripod Mount Replacement: adım 4, 2 resimden 1. Minolta Maxxum QTSI Tripod Mount Replacement: adım 4, 2 resimden 2.
    • Use the tweezers to gently remove the tripod socket, and replace it.
Sonuç
Jordan Ellery
388 İtibar
3 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 334
