Ana içeriğe geç
Minolta Maxxum STsi Back Clock Button Replacement
Neye ihtiyacın var
  1. Minolta Maxxum STsi Back Clock Button Replacement, Back Clock Button: adım 1, 1 resimden 1.
    • Open the back panel by firmly pressing up on the back-cover release on the lower right side of the camera.
  2. Minolta Maxxum STsi Back Clock Button Replacement: adım 2, 3 resimden 1. Minolta Maxxum STsi Back Clock Button Replacement: adım 2, 3 resimden 2. Minolta Maxxum STsi Back Clock Button Replacement: adım 2, 3 resimden 3.
    • Remove the black case by gently lifting it with your fingers and rotating counterclockwise.
  3. Minolta Maxxum STsi Back Clock Button Replacement: adım 3, 2 resimden 1. Minolta Maxxum STsi Back Clock Button Replacement: adım 3, 2 resimden 2.
    • Remove the five black Phillips #00 2.5 mm screws from the back panel.
    • Also remove the two black Phillips #00 5.0 mm screws from the back panel.
  4. Minolta Maxxum STsi Back Clock Button Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use the tweezers to carefully peel back the adhesive foam connecting the back panel to the case and remove the panel.
  5. Minolta Maxxum STsi Back Clock Button Replacement: adım 5, 2 resimden 1. Minolta Maxxum STsi Back Clock Button Replacement: adım 5, 2 resimden 2.
    • Use the tweezers to carefully peel off the rubber clock button.
Sonuç
Jacobe Labog
301 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-12, Amido Spring 2015 Cal Poly, Team 14-12, Amido Spring 2015 üyesi
CPSU-AMIDO-S15S14G12
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 510
