Ana içeriğe geç
Minolta QTsi Maxxum Shutter Button Replacement
Neye ihtiyacın var
  1. Minolta QTsi Maxxum Shutter Button Replacement, Shutter Button: adım 1, 1 resimden 1.
    • Locate the battery compartment on the bottom panel of the camera.
    • Open the battery door by using a coin.
    • In the counterclockwise direction, twist the coin in the battery door groove to open it.
  2. Minolta QTsi Maxxum Shutter Button Replacement: adım 2, 1 resimden 1.
    • Two batteries are located inside the battery chamber.
    • Remove the two batteries from the battery chamber by picking them up.
  3. Minolta QTsi Maxxum Shutter Button Replacement: adım 3, 1 resimden 1.
    • There is a screw located underneath the batteries in the battery compartment.
    • Unscrew and remove the (1) black Phillips #00 5mm screw from the battery compartment.
    • Ensure good lighting before attempting to remove this screw because it is hard to see inside the compartment.
  4. Minolta QTsi Maxxum Shutter Button Replacement: adım 4, 1 resimden 1.
    • From underneath the flash assembly, remove the (1) black Phillips #00 5mm screw
    • Be careful because you can lose the screw
  5. Minolta QTsi Maxxum Shutter Button Replacement: adım 5, 1 resimden 1.
    • The only screws remaining that hold the top panel of the camera in place are located next to the view finder.
    • Remove the (2) black Phillips #00 5mm screws from both sides of the view finder.
  6. Minolta QTsi Maxxum Shutter Button Replacement: adım 6, 2 resimden 1. Minolta QTsi Maxxum Shutter Button Replacement: adım 6, 2 resimden 2.
    • The top panel of the camera should now be easy to lift off. If it is not, make sure that all screws and attachments, listed in steps 1-5, have been removed.
    • Once all screws are removed, lift the top panel from the camera.
    • Be careful when removing the top panel because there are wires connected to it.
  7. Minolta QTsi Maxxum Shutter Button Replacement: adım 7, 1 resimden 1.
    • Use a metal spudger to push the button out of its socket so that you can place a new one in its place.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jordan Ellery
388 İtibar
3 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 551
