Ana içeriğe geç
Minolta QTsi Maxxum View Finder Replacement
Neye ihtiyacın var
  1. Minolta QTsi Maxxum View Finder Replacement, View Finder: adım 1, 1 resimden 1.
    • Locate the battery compartment on the bottom panel of camera.
    • Use a small coin to untwist and open the batter compartment door.
    • Twist the coin counterclockwise to unlock the battery compartment door.
  2. Minolta QTsi Maxxum View Finder Replacement: adım 2, 1 resimden 1.
    • Two batteries are located inside the battery compartment
    • Be careful, the batteries inside the compartment are small and easy to lose.
    • Remove the two batteries from inside the battery compartment by individually pulling each out.
  3. Minolta QTsi Maxxum View Finder Replacement: adım 3, 1 resimden 1.
    • When the batteries are removed from the compartment, one screw will be visible in the bottom of the chamber.
    • Unscrew the (1) black Phillips #00 5mm screw from the bottom of the battery chamber.
    • Be careful when unscrewing the screw because it's small and is easy to lose.
  4. Minolta QTsi Maxxum View Finder Replacement: adım 4, 1 resimden 1.
    • Remove the (2) black Phillips #00 5mm screws that lie on either side of the view finder.
    • Be careful because the two screws are small and are easy to lose.
  5. Minolta QTsi Maxxum View Finder Replacement: adım 5, 1 resimden 1.
    • Remove the (1) black Phillips #00 5mm screw from underneath the flash hood.
    • Be careful because the screw is small and is easy to lose.
  6. Minolta QTsi Maxxum View Finder Replacement: adım 6, 2 resimden 1. Minolta QTsi Maxxum View Finder Replacement: adım 6, 2 resimden 2.
    • Once all screws are removed, the top of the camera should come off easily.
    • Be careful when removing the top, there are wires connected that could be damaged.
  7. Minolta QTsi Maxxum View Finder Replacement: adım 7, 1 resimden 1.
    • The viewfinder will fall when the screws are removed.
    • Remove the (2) black Phillips #00 5mm screws that hold the viewfinder.
    • Be careful because the screws are small and easy to lose.
Sonuç
Maya Van Londen
315 İtibar
2 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 1,104
