Ana içeriğe geç
Minolta X-370 Battery Replacement
Neye ihtiyacın var
  1. Minolta X-370 Battery Replacement, Battery: adım 1, 2 resimden 1. Minolta X-370 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the camera so that the bottom is facing you.
    • Take a spare coin and unscrew the battery cover off.
  2. Minolta X-370 Battery Replacement: adım 2, 1 resimden 1.
    • Remove the batteries, making sure to note their proper alignment.
    Hi just checking which type of batteries are required? You have two types listed, the SR44/LR44 (I understand those are the same types of batteries) then the CR-1 / 3 /3N 3V battery? How many batteries do I need and which type will I need? thanks!
    Juliette Perry-Dumarquez - Yanıt
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Nick
525 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-7, Regan Spring 2011 Cal Poly, Team 8-7, Regan Spring 2011 üyesi
CPSU-REGAN-S11S8G7
4 Üyeler
9 adet Kılavuz yazıldı
1Rehber Yorum
Hi there, i'm a bit stuck, in my 35mm SLR i was taking a shot and the batteries died, leaving the mirror stuck in the up position, i've changed the batteries and the release for the shutter won't click, i can't advance the film lever and so it's a sitting duck at the moment. They're brand new batteries but because the mirror is up i can't even see if the metering works. because i'm half way through a roll of film i don't want to open the back and ruin it so i'm wondering if there's any way to get the shutter to release again or to get the mirror back down, i don't mind loosing a few blank exposures but again i really wouldn't want to ruin the film. Many thanks and i hope you can get back to me,
Cameron
Cameron Tyson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 31
Son 30 gün: 158
Her zaman: 22,798
