Giriş
If the battery on the watch is working but you are struggling to turn on the watch via the power button then it might be time to replace the power button. You will need tweezers, jaxa wrench, and and iFixit opening tool.
Neye ihtiyacın var
Using your fingers, press down on the rubber circles to unbuckle the strap from itself.
Once you have removed two of the rubber circles from from a side you will be able to unbuckle the strap on that side.
Use the tweezers to gently push out the button from the frame of the watch.
