Ana içeriğe geç
Mitsubishi Diamondpoint NXM76LCD Display Replacement
Neye ihtiyacın var
  1. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Removing the stand.: adım 1, 3 resimden 1. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Removing the stand.: adım 1, 3 resimden 2. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Removing the stand.: adım 1, 3 resimden 3.
    • Lift the black cover off.
    • Remove all 4 Phillips #2 screws.
  2. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the 5 screws: adım 2, 1 resimden 1.
    • Remove the two 24mm Phillips #2 screws.
    • Remove the three 8mm Phillips #2 screws.
  3. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the back panel: adım 3, 3 resimden 1. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the back panel: adım 3, 3 resimden 2. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the back panel: adım 3, 3 resimden 3.
    • Lift the back and pry the back off.
    • The panel is held in with clips on the side. It needs a lot of force the take it off.
  4. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: adım 4, 2 resimden 1. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: adım 4, 2 resimden 2.
    • Remove the four 5mm nut screws.
  5. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the 5 screws: adım 5, 2 resimden 1. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the 5 screws: adım 5, 2 resimden 2.
    • Remove the seven Phillips #1 screws.
  6. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the front panel: adım 6, 2 resimden 1. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the front panel: adım 6, 2 resimden 2.
    • Remove the three Phillips #2 screws.
    • Remove the two data/power cables.
    • Remove the two speaker cables.
  7. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display cable: adım 7, 3 resimden 1. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display cable: adım 7, 3 resimden 2. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display cable: adım 7, 3 resimden 3.
    • Pull the two tabs.
    • Pull the connector off.
  8. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the power switch: adım 8, 2 resimden 1. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the power switch: adım 8, 2 resimden 2.
    • Remove the switch cable off.
    • Remove the two Phillips #2 screws.
  9. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display power: adım 9, 2 resimden 1. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display power: adım 9, 2 resimden 2.
    • Remove the four display power cables.
    • These cables are interchangeable.
  10. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Lift the display out: adım 10, 3 resimden 1. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Lift the display out: adım 10, 3 resimden 2. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Lift the display out: adım 10, 3 resimden 3.
    • Lift the display out.
  11. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: adım 11, 2 resimden 1. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: adım 11, 2 resimden 2.
    • Remove the four Phillips #2 screws.
    • These screws release the display from its enclosure. Hold the screen when removing these screws.
  12. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement: adım 12, 2 resimden 1. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement: adım 12, 2 resimden 2.
    • Remember to plug in all the cables on the display.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Padraic Hoselton
4.339 İtibar
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 317
