Ana içeriğe geç
Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement
Neye ihtiyacın var
  1. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Removing the stand.: adım 1, 3 resimden 1. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Removing the stand.: adım 1, 3 resimden 2. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Removing the stand.: adım 1, 3 resimden 3.
    • Lift the black cover off.
    • Remove all 4 Phillips #2 screws.
  2. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the 5 screws: adım 2, 1 resimden 1.
    • Remove the two 24mm Phillips #2 screws.
    • Remove the three 8mm Phillips #2 screws.
  3. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the back panel: adım 3, 3 resimden 1. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the back panel: adım 3, 3 resimden 2. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the back panel: adım 3, 3 resimden 3.
    • Lift the back and pry the back off.
    • The panel is held in with clips on the side. It needs a lot of force the take it off.
  4. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the four screws: adım 4, 2 resimden 1. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the four screws: adım 4, 2 resimden 2.
    • Remove the four 5mm nut screws.
  5. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the 5 screws: adım 5, 2 resimden 1. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the 5 screws: adım 5, 2 resimden 2.
    • Remove the seven Phillips #1 screws.
  6. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the cables: adım 6, 3 resimden 1. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the cables: adım 6, 3 resimden 2. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the cables: adım 6, 3 resimden 3.
    • Remove all the cables.
  7. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the motherboard: adım 7, 3 resimden 1. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the motherboard: adım 7, 3 resimden 2. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the motherboard: adım 7, 3 resimden 3.
    • Remove the four screws.
    • Pull the motherboard up and off.
  8. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement: adım 8, 1 resimden 1.
    • Now you can replace it with a new one.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Padraic Hoselton
4.204 İtibar
12 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
321 Üyeler
1.512 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 152
