Ana içeriğe geç
Mitsubishi Diamondpoint NXM76LCD Speaker Replacement
Neye ihtiyacın var
  1. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Removing the stand.: adım 1, 3 resimden 1. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Removing the stand.: adım 1, 3 resimden 2. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Removing the stand.: adım 1, 3 resimden 3.
    • Lift the black cover off.
    • Remove all 4 Phillips #2 screws.
  2. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the 5 screws: adım 2, 1 resimden 1.
    • Remove the two 24mm Phillips #2 screws.
    • Remove the three 8mm Phillips #2 screws.
  3. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the back panel: adım 3, 3 resimden 1. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the back panel: adım 3, 3 resimden 2. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the back panel: adım 3, 3 resimden 3.
    • Lift the back and pry the back off.
    • The panel is held in with clips on the side. It needs a lot of force the take it off.
  4. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the four screws: adım 4, 2 resimden 1. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the four screws: adım 4, 2 resimden 2.
    • Remove the four 5mm nut screws.
  5. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: adım 5, 2 resimden 1. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: adım 5, 2 resimden 2.
    • Remove the seven Phillips #1 screws.
  6. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the front board: adım 6, 2 resimden 1. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the front board: adım 6, 2 resimden 2.
    • Remove the three Phillips #2 screws.
    • Remove the two data/power cables.
    • Remove the two speaker cables.
  7. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: adım 7, 2 resimden 1. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: adım 7, 2 resimden 2.
    • Remove the Phillips #2 screws from the speaker(s).
  8. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: adım 8, 3 resimden 1. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: adım 8, 3 resimden 2. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: adım 8, 3 resimden 3.
    • Pull the speaker off the slots.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Padraic Hoselton
4.282 İtibar
12 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
327 Üyeler
1.673 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 26
Her zaman: 150
