Ana içeriğe geç
Mitsubishi Electric DD-6040 Power Button Replacement
Neye ihtiyacın var
  1. Mitsubishi Electric DD-6040 Power Button Replacement, Power Button: adım 1, 3 resimden 1. Mitsubishi Electric DD-6040 Power Button Replacement, Power Button: adım 1, 3 resimden 2. Mitsubishi Electric DD-6040 Power Button Replacement, Power Button: adım 1, 3 resimden 3.
    • Unplug your DVD player prior to working on the device.
    • Remove five 1.2 mm Phillips #1 screws to disassemble the DVD player.
  2. Mitsubishi Electric DD-6040 Power Button Replacement: adım 2, 3 resimden 1. Mitsubishi Electric DD-6040 Power Button Replacement: adım 2, 3 resimden 2. Mitsubishi Electric DD-6040 Power Button Replacement: adım 2, 3 resimden 3.
    • Once the screws are removed, slide back and remove the cover.
  3. Mitsubishi Electric DD-6040 Power Button Replacement: adım 3, 3 resimden 1. Mitsubishi Electric DD-6040 Power Button Replacement: adım 3, 3 resimden 2. Mitsubishi Electric DD-6040 Power Button Replacement: adım 3, 3 resimden 3.
    • Gently pull out the green circuit board.
    • Be very careful, as circuit boards can be quite fragile.
  4. Mitsubishi Electric DD-6040 Power Button Replacement: adım 4, 2 resimden 1. Mitsubishi Electric DD-6040 Power Button Replacement: adım 4, 2 resimden 2.
    • Flip the DVD player over and pull up on the clip.
  5. Mitsubishi Electric DD-6040 Power Button Replacement: adım 5, 3 resimden 1. Mitsubishi Electric DD-6040 Power Button Replacement: adım 5, 3 resimden 2. Mitsubishi Electric DD-6040 Power Button Replacement: adım 5, 3 resimden 3.
    • Once the clip is unlatched disconnect the corner tabs.
    • Reorient and unlatch the tabs inside the device.
    • Remove the faceplate.
  6. Mitsubishi Electric DD-6040 Power Button Replacement: adım 6, 3 resimden 1. Mitsubishi Electric DD-6040 Power Button Replacement: adım 6, 3 resimden 2. Mitsubishi Electric DD-6040 Power Button Replacement: adım 6, 3 resimden 3.
    • Pull on the old power button to remove it.
  7. Mitsubishi Electric DD-6040 Power Button Replacement: adım 7, 2 resimden 1. Mitsubishi Electric DD-6040 Power Button Replacement: adım 7, 2 resimden 2.
    • Adjust and push the new button into place.
Sonuç
To reassemble your device, follow these steps in reverse order.
Bir başkası bu kılavuzu tamamladı.
Usha Alexis
199 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 351
